Intermittent Spark Issue
Old Sep 14, 2006 | 12:25 PM
bg552's Avatar
Been having this problem for the past 2 months now and havent been able to drive the car for fear of getting stranded. Most of the time, the car will start and run normally for 10 minutes or more. During this time, the car runs flawlessly (no miss, rough idle or anything). At some point after that, the engine will completely quit without any sort of warning. Sometimes it will start back up and run fine, then quit again the same way, or it wont start back up at all. Had it out the other day, it lost power, backfired, regained power and then stalled a minute later. Where do i go next trying to track down this issue. I have already replaced:
- Optispark distributor (cap and rotor looked fine and were not replaced)
- Spark Coil
- Ignition Control Module
- O2 Sensors
Someone please point me in the right direction as to what to do next...thanks
Old Sep 14, 2006 | 12:56 PM
bg552's Avatar
Re: Intermittent Spark Issue
Also, is there any way that this could possibly be linked to the fuel pump?
Old Sep 14, 2006 | 09:40 PM
OBE1 95Z28's Avatar
Igntion switches have been known to go bad. Do all you dash lights go out when it dies?
Old Sep 14, 2006 | 11:09 PM
bg552's Avatar
No the check gauges light stays on...
Old Sep 15, 2006 | 10:36 AM
bg552's Avatar
Checked it last night after i had problems again and there was no spark at the coil whatsoever...anybody? please help this is ridiculoous
Old Sep 16, 2006 | 06:14 AM
Guest47904's Avatar
Guest
Do you have a problem when it goes into closed loop?
Try unplugging one of the O2s and see if it runs better when it trys to go into closed loop. You will know for sure it tried to go to closed loop when the SES trips.
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
