intermittent low speed miss - was low dyno numbers
Old Sep 7, 2004 | 07:12 PM
llafro's Avatar
I posted a couple of weeks ago about low dyno numbers.
low dyno thread
I changed the plugs and wires, and that seemed to clear up the problem. The car seems much more powerful now. It also sounds much better, less raspy. I had one cylinder that was completely dead - the plug was bright and shiny. That had to be playing havoc with the mixture on that side of the engine. So, the good news is that I made 306 rwhp on only seven cylinders, and three of those had to be running rich due to the dead cylinder.
The bad news is that now I have an intermittent miss that seems to come on only after the car is good and hot. The problem is that the miss is only evident some of the time. For example, going to full throttle in 6th gear only causes it about half of the time.
Everything worked for a few days after I changed out the plug wires. I don't see any arcing of the wires in the dark. So now what? Any suggestions?
BRAD
Old Sep 7, 2004 | 07:40 PM
flyinZ's Avatar
Re: intermittent low speed miss - was low dyno numbers
Any codes, bein' thrown?
Just a thought, but it might be your opti..
Old Sep 7, 2004 | 07:59 PM
N2OMARO's Avatar
Sounds like a broken valve spring to me. Had a problematic miss that matches your symptoms. Mine was the #7 cylinder exhaust.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Joe Brodman
Jul 24, 2002 05:24 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
