intermediate headers just as good as long tubes
Old Feb 10, 2004 | 10:09 PM
  #16
Live for TAs's Avatar
Sort of OT- I miss Jeff Smith...
Chevy High Performance has gone downhill since Jeff left. It is hard to understand some of the stuff the new guy writes. I bought a subscription to Car Craft (where Jeff is now the Editor and apparently writes like 75% of the articles) for this reason.
Back on topic...
I referenced the same CHP header article in this thread . I was interested in this article because my 383 has 9:1 compression (due to planning for a blower), and my car is lowered, so I was concerned about the LT headers regarding ground clearance. I'm still waiting to read some real world stories with the Pacesetters.
Old Feb 10, 2004 | 10:28 PM
  #17
simple's Avatar
sorry off topic but "Live for TA's" i like your next project listed in your sig man 2 words..... DO IT!
Old Feb 11, 2004 | 08:44 AM
  #18
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
live 4 i read your thead and was amazed. those shorty numbers for average under the curve were right there and no one even mentioned it the entire rest of the thread. sometimes i think people just want to get there post on here somewhere and dont even read what its about.
david
Old Feb 11, 2004 | 09:02 AM
  #19
WS Sick's Avatar
Originally posted by dren70
jason here are the averages.
the purpose of the post was to dispell the RUMOR that long tubes are so much better than intermediate or even shorties. the only concrete shorty info i can give will be my dyno when the heads are completed. as for the intermediate the averages were minimally different. unless you need to tap every single ounce of power like 383Z4ME in his drag car you can do quite well with a solution other than long tubes. i would prefer 10 lbs of torque out of the hole instead of 20 HP at the top.
WS Sick i checked out the link.
The comparison test pitted the stock cast-iron exhaust manifolds against a set of 1-5/8-inch Hooker headers that were plumbed into the same 2-½-inch exhaust system
i am not sure how this applies to this post. no one would disagree that anything is better than stock.
david
My point is that every instance requires a differnt approach, for instance the headers tested in the article youre touting have a specific cam etc. if you would change cams to complement the larger headers , increase compression then which do you think would perform better.
A blanket statement saying that this sucks and this is the best only applies to the test engine used and the purposed stated.
Saying that this header is better just because it performed better on a moter (which is completly different by the way than what your engine would require) is putting blinders on your head.
If the motor only needs 1 5/8s then they will be fine but there is a point that the 1 5/8s will not do well.
if your goal is different then mine they do we not have to take different approaches to acheive our goals.
Old Feb 11, 2004 | 01:36 PM
  #20
dren70's Avatar
this is not about changing cams for a set of headers. maybe a set of edelbrock or bbk are better than the flow tech so they would do better with increased compression or a bigger cam.
nobody said anything sucks or whats best for an engine. again the point is intermediate headers are comperable to long tubes. thats all i am getting at and the average numbers for all 4 headers from 3000 to 6000 are similar and almost identical.
maybe i am talking apples and you are talking oranges.
david
Old Feb 11, 2004 | 01:59 PM
  #21
WS Sick's Avatar
David, I know you didnt say anything sucked as per this subject, but what my point is , is that the test was good for that combo, if you have something different than what they have then the results of course will be different, in some cases the intermediate and or shorter length headers will compare, but when the bar is raised so will the seperation between the two.
If your LT is going to do 90 percent commute driving and 0 percent track time then you have to decide if you can live with the longtubes, or go shorties and see a gain, but lose a few at the track.
Old Feb 11, 2004 | 09:38 PM
  #22
Thanks! I'm looking forward to doing this (and it should run cooler than the Mazda did), but have a couple of other things to do first.
Cam's maro
Jan 30, 2015 09:21 PM
ModdedNerd
Jan 1, 2015 10:56 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
Queens94z28
Nov 20, 2014 06:03 PM
Jul 4, 2005 05:00 PM
