Intermediat low RPM miss
My car has recently developed a low RPM miss, from idle-2K sometimes, and it doesn't do it all the time, mabey 1 in 10 times starting off, or if I'm cruising at ~1500-2K and I give it more gas it just misses. It kind of feels like I'm hitting a rev limiter, but its still accelerating. I have a new opti, new plugs, new wires, and a new coil, but it's still doing it.
The only thing that I haven't changed in my ignition is the ignition control module, do you guys think thats it?
Re: Intermediat low RPM miss
Originally Posted by Hawk
try ICM cooling mod, double check plugs and wires.
Brian
Brian
Originally Posted by speed_demon24
My plugs/wires/opti/coil are all less than a month old, and none of the wires are burnt at all. They aren't even close to touching the headers.
Do you get what seems like a really rich pop coming out of the tail pipe once the car is warmed up and idling?
Originally Posted by matLT1
I have something similar going on. At low rpm I will get a miss and if I let off the gas then get back in it will be fine. It only happens a couple of times per week. I have already done the cooling mod though. I recently did the plugs and wires also.
It's getting worse and doing it more often. It pops every once in a while while its missing. The injectors are only a few months old so I doubt its that, and it doesn't seem down on power when its not missing so I doubt its a bad fuel pump. I guess I'm just going to try the ICM and see if it works.
Noenav
Apr 30, 2015 01:06 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
