Intalling GM 1.6 RR with engine running
Old Jun 6, 2004 | 02:00 PM
)2overt SS's Avatar
I tried many searches.. but I'm still confused..
I don't have the RR yet but I will this week..
I have installed rockers before. But that was on an engine that was on a stand... so I could rotate the crank etc... I know how to set them to zero lash and I know how to preload them (for this particular set I had to do one full rotation if I remember correctly)
But how do you do this on a running engine? I'm not doing a cam swap for a while.. and I'm getting a good deal on these RR so I can't really just wait.
Does anyone have a website or a guide? I'm confused about things like.. how do I get the cylinders to TDC without rotating the crank by hand?
Thanks guys
Old Jun 6, 2004 | 02:03 PM
Spinner's Avatar
Re: Intalling GM 1.6 RR with engine running
Thanks guys
Use the starter. Pull the spark plugs, injector connectors, and coil wire.
Old Jun 6, 2004 | 03:09 PM
12SCNDZ's Avatar
...Save yourself some aggrivation...adjust them with the engine running.
Frank
Old Jun 6, 2004 | 03:49 PM
)2overt SS's Avatar
Frank
Thats where I am confused... I take my old rockers off.. and put the new ones on.. but now, before I start the engine, how do I know if they are too tight, or not tight enough for the engine to run ok, so that I can do the final adjustments?
Old Jun 6, 2004 | 04:44 PM
Adjusting methods
Old Jun 6, 2004 | 07:21 PM
TenaciousZ's Avatar
First adjust them by finding either 1 or 6 TDC then you can adjust them with the car running to fine tune em.
Old Jun 6, 2004 | 07:29 PM
bunker's Avatar
yeah just adjust them to about 1/4 turn past zero lash, I say this because you wnat them as quite as possible or you'll get a head ache while adjusting while running then when engine is running let it warm up to the temp you will be running the car, ie. 180*F, just look on temp guage, anyways now back off one rocker a bit, & loosen it's set screw about 1-2 turns, now loosen the nut more until it start making noise, now just turn it to tighten with your fingers, you'll know when the noise goes away, but don't worry I just use noise as a reference but when you hit zero lash you'll feel it with your fingers cuz the nut won't tighten easy anymore, try it you'll know right away what I mean, you keep tightening the nut for noise to go away & then you can't turn it anymore, don't try to go harder cuz you'll succeed & it won't be zero lash anymore, but once you can't turn it easy anymore hold the nut in that position with one hand & tighten set screw with the other, when set screw is tight (make sure nut doesn't turn when you tighten set screw, you might need to use a wrench at times) well when set screw is tight just put a socket on the whole rocker nut & give it a snug turn, this will wedge the set screw against the stud much better then just tightening the set screw, this will give you the proper preload aswell, about 1/25th of a turn past or so.
Try it & this will all make sense bud, & enjoy, your car will rev to the moon & never stop
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
Lions3
Apr 11, 2003 10:55 AM
