idle value
Old Jun 6, 2004 | 04:13 PM
fearnside5's Avatar
idle value
What is the rpm value at idle of a 95 Z28 A4? Requested idle is 725 via a tech 1 and I'm around 700 -725 in park or neutral. In drive I'm around 550 - 625 and with the a/c on idle drops to around 470 - 525. No dtcs present and no ses light. Car had a higher idle before battery disconnected ( 800 - 900 ). I'm assuming the iac has been relearning after the batt was disconnected since the idle has improved from the 500 range to around 700 ( not in drive ). I have a friend at a dealership who borrowed a tech 1 but, neither of us have any experience using this scanner. What values are in normal operating range for a LT1?
Old Jun 6, 2004 | 04:31 PM
Hot idle is 650 in Park and 550 in Drive. If you are seeing 725 requested, it is probably not fully warm. However, what is requested should be close to what it is idling at the time.
Old Jun 6, 2004 | 07:51 PM
fearnside5's Avatar
Thanks for the reply. I've been to your page and learned quite a bit.
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
