Intake Question
Old Jun 3, 2011 | 08:35 PM
Tiron's Avatar
Intake Question
Alright, so a little bit of background first. I recently bought a 1997 Z28 on the cheap, and I'm in the process of fixing it up. When I got it, it had no muffler, a broken trans mount (and later discovered a broken engine mount), no stereo head unit, numerous missing dashboard items, and a window that had been pulled out of its track. It also had a large exhaust leak and a lean code. But, for $2k I couldn't turn it down.
Anyways, on to my questions...
1: Why does the K & N intake kit say it won't work on a vehicle with traction control? I don't see anything under the hood that would get in the way (that I recognize is traction control related anyway). Has anyone tried this?
2: My intake boot is torn badly (cause of the lean code, I thought at first it was the exhaust leaks), I've duct taped it as a temporary solution. I've been looking at some aftermarket ones, but none of them have a hole for what I think is an A.I.R. tube. I attached a picture of it. Does anyone know what this is exactly, and if it can be moved somewhere else?
Here is the one I am looking at, it has a hole for the IAT but not the second tube:
http://www.jegs.com/i/JEGS+Performan...57020/10002/-1
Old Jun 3, 2011 | 09:02 PM
Camaro350z28's Avatar
Re: Intake Question
for the k&n intake i believe it dont fit on traction control car because where the filter sits. you cant see from in the engine bay, you gotta get under the car. there is a box for i believe cruise that gets moved to a spot where it would interfere.
as for your intake elbow. that hose is for the vented optispark. none of the aftermarket ones come with the hole, however they come with instructions where to drill a hole and what side hole to drill. also comes with the grommet to stuff in hole then just push your hose into it.
Old Jun 3, 2011 | 09:03 PM
Re: Intake Question
oh, find a vortech elbow or search the for sale section. you should find one in there. i have no experience with the jegs model. but i do know my elbow came with the step by step
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
mikey4play
Mar 15, 2015 11:45 AM
LT14LIFE
Feb 9, 2015 09:35 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
