Intake oil leak fix...how long?
Old Jun 29, 2003 | 08:26 PM
  #16
Originally posted by craigffb
Cool, thanks guys. I have a manual so I'll check it before I start.
In case you don't find the torque sequence...(courtesy of Alex A)
Old Jun 30, 2003 | 11:22 PM
  #17
craigffb's Avatar
I've got two more questions. Do the fuel rails need to come off, or can I leave them on? And should I use Brake cleaner or Carburetor cleaner?
Old Jul 1, 2003 | 03:34 AM
  #18
Wilson's Avatar
Smile
Its probably easier to work on the intake if you take the rails off. It only takes a few minutes to remove the fuel rails if you got the tool. As for cleaning the surface it doesnt really matter what solvent you use just make sure to wipe down the area before applying the sealant. Put a big **** bead on the back & front of the intake. Let it sit for awhile so it can harden up a bit and then torque the thing down. Its a pretty easy job to do but its time consuming cause after you put everything back together you should let the car sit for 24hrs. After a few days you want to retorque everything to spec to make sure none of the bolts came loose.
Old Jul 1, 2003 | 04:00 AM
  #19
jkipp84's Avatar
A few tips I've come across that helped:
Keep track of what bolt went where. I used a shoe box flipped over, note one end front or back representative of the intake. Poke holes, put in each bolt roughly where it came out of. Then there'll be no confusion as to what went where when it's time to reinstall the manifold.
Score the lip of the block where the RTV in the back (I did the front too) will go. I used the corner of a file and made some deep X's all the way across it. Especially near the EGR area. Before that I also hit it up with some rough sand paper. Same thing on the manifold. These help give the RTV something to stick to. You'll notice when you remove the intake, these areas are very smooth.
When reinstalling the manifold, you don't want to be sliding it around to line up the holes, you'll wind up shoving RTV off. I broke off a piece of pencil and put that in one of the bolt holes. Drop the manifold in using that as a guide. Just make sure it's long enough to grab after the manifold is down.
If you're not all that familiar with the wires and vacuum lines, you may want to take a few pics first or at least label them.
As mentioned - let that RTV set! It may be tempting to start it up, but you don't want to have to do it all over again.
Good luck
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
artic94
Jan 17, 2015 11:19 AM
Jul 4, 2005 05:00 PM
