Intake Nut/Stud question
Old Oct 17, 2010 | 08:46 PM
97whiteboy's Avatar
On a 97 Camaro Z-28. The Intake Bolts appear to be a Stud and Nut. How should they be removed and reinstalled. The nut only or nut/stud together. As far as reinstall stud first or together. They are pretty much burried. (Intake Fore Aft Seal leak Fix) First time attempt.
Old Oct 17, 2010 | 08:58 PM
walt355's Avatar
Its actually a bolt with a stud on top. When you loosen them it will all come out. Just not where they go back
Old Oct 17, 2010 | 09:27 PM
Your bolt/studs will be looking something like this.
Old Oct 18, 2010 | 02:16 AM
97WS6SCharged's Avatar
Mine look nothing like that.
Old Oct 18, 2010 | 12:23 PM
97whiteboy's Avatar
Thanx
Due to a tight clearance between the manifold and compartment, what is the best way to deal with the rear EGR valve tube and wiring along the sides of the manifold. I'm sure many of you have some great experience with this. My first time on this leak problem. any info would by so helpful. Thanx
Old Oct 18, 2010 | 01:34 PM
You merely take the EGR pipe nuts off (1/2" wrench size) and free the tube. The wiring can be disconnected from the injectors and such and laid aside.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
mikey4play
Mar 15, 2015 11:45 AM
LT14LIFE
Feb 9, 2015 09:35 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
