Intake Nut/Stud question
On a 97 Camaro Z-28. The Intake Bolts appear to be a Stud and Nut. How should they be removed and reinstalled. The nut only or nut/stud together. As far as reinstall stud first or together. They are pretty much burried. (Intake Fore Aft Seal leak Fix) First time attempt.
Thanx
Due to a tight clearance between the manifold and compartment, what is the best way to deal with the rear EGR valve tube and wiring along the sides of the manifold. I'm sure many of you have some great experience with this. My first time on this leak problem. any info would by so helpful. Thanx
oldschool
Feb 9, 2016 09:21 PM
