Intake Maniforld questions
Purchased a 1994 Z28 a few months ago and it appears to have the famous LT1 intake manifold leak. Have read several of the threads and fixes, but have a couple of questions. What size (and thread) are the intake manifold bolts? Wanted to make a couple of studs to align the intake when installing. Do you need to purchase a EGR pipe gasket (for the connection on the back of the intake manifold) or can this gasket be re-used?
3/8 Inch-16 I'm pretty sure - you might find some studs in that thread and just put a couple on one side to use as guides. I never did though, and i've done it a bunch of times. Your egr gasket may come apart, or it might be reusable - they're pretty cheap new though.
I didn't receive EGR gaskets with fel-pro intake manifold gaskets that i have bought before. Just FYI, if you go to get EGR gaskets, there are 2 different ones that you need, so if you are trying to be prepared, be sure to get both!
oldschool
Feb 9, 2016 09:21 PM
