Intake manifold gaskets, put on dry or a spray on sealant?
Old Jun 23, 2003 | 07:17 PM
$hawn's Avatar
On the intake manifold gaskets, the metal ones that come in the fel pro set, do you suggest that I put them on dry or use a spray on sealant? If a spray on sealant, which kind, the regular or copper spray.
Old Jun 23, 2003 | 07:26 PM
superal's Avatar
I'd imagine n/a you will be fine with no sealant except the front and back of course. I spread a thin layer of copper rtv from a tube on my gasket just because there's no reason not to. Works good so far.
Old Jun 23, 2003 | 07:33 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
http://www.worldisround.com/articles.../photo100.html
do that dremel a line into the block and into the intake to match. silicone up and it makes a "wall."
Old Jun 23, 2003 | 11:32 PM
$hawn's Avatar
I got the intake off, and I noticed that the factory gaskets arent metal, would the metal ones work better, or should I get some GM factory ones? I figure that the aluminum ones would be a better choice cause the intake and heads and gaskets would all be the same material, but I could be wrong, or does it matter much either way? Thanks guys.
Old Jun 23, 2003 | 11:58 PM
superal's Avatar
I'm guessing Felpro knows what they're doing. Mine were plastic victor gaskets but that's all I could find at NAPA and I needed them right away. I would have gone felpro if I had the time to order.
Old Jun 24, 2003 | 07:06 AM
94_Z28_guy's Avatar
Did you notice 2 white plastic tabs in the gasket? I assume those stay in? Or do you take them out, and what are they for? I am about to put mine on tonight, and couldn't figure out what the plastic things were.
BTW, I am putting them on dry. You shouldn't need any extra, except for the back and front like was already said.
Old Jun 24, 2003 | 07:18 AM
I used the Felpro gaskets. Put them on dry, leaving the white, plastic locator pins on. I used Ultra Copper on the end rails. I'm sure a spray on copper sealant would not hurt anything, just don't know that it is necessary.
CARiD
Jan 27, 2015 06:27 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
