Intake manifold bore size?
Old Jul 2, 2008 | 01:25 AM
dubbsix's Avatar
I tried a search but couldnt find any threads: What is the size of opening in the LT1 intake manifold behind the throttle body?
Going with a cc503 cam and was thinking about upgrading to a 52MM TB, but wanted to know if i would need to have the bore increased in the manifold.
Old Jul 2, 2008 | 05:20 AM
52mm
Old Jul 2, 2008 | 11:00 AM
dubbsix's Avatar
Stock TB
And whats the size of the stock LT1 throttle body? Is it 52mm as well?
Old Jul 2, 2008 | 11:19 AM
HottestZ28's Avatar
i BELIEVE IT IS 48MM OR 47MM
Old Jul 2, 2008 | 01:48 PM
seawolf06's Avatar
Stock TB is 48mm.
Old Jul 2, 2008 | 02:02 PM
dubbsix's Avatar
even necessary?
Im in the process of installing the following and would like to know if 52 will work or if i'll need to step up to 58mm
cc503 cam
1.6 pro mag
pace setter mids
mail order tune
Old Jul 2, 2008 | 02:15 PM
seawolf06's Avatar
You will be fine with a stock size TB. If you want, you could see some gains in getting a 54mm stock TB. There is a guy on ebay that does them and he will give you some money back if you send him your stock one. I think I remember reading that a couple people here were happy with his service.
Old Jul 2, 2008 | 03:11 PM
dubbsix's Avatar
So is the general idea... that its not bad to upgrade to 52-54mm, but a 58mm would be over kill?
Old Jul 2, 2008 | 03:43 PM
seawolf06's Avatar
I've seen more people have problems with the aftermarket throttle bodies and they don't provide much, if any, better results.
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
