Intake Manifold
Old Jan 16, 2009 | 11:45 AM
  #16
You aren't going to gain anything by "porting" the LT1 intake manfiold, used on stock (unported) heads. Don't worry about it.
Old Jan 16, 2009 | 03:57 PM
  #17
BLKOUTZ28's Avatar
If you don't have experience in porting do not attempt it. Leave it alone unless you want new heads and then have someone experienced do it for you. Black or red and polish the center strips to make it look nice and shinny. I would hook up the fuel rails with a good polish if you can get to them properly (JMO). Pictures of a LS1 with painted intake and polished fuel rails.
http://www.cardomain.com/ride/314999/3
Old Jan 16, 2009 | 08:40 PM
  #18
jtarp's Avatar
Thanks guys
Old Jan 18, 2009 | 12:14 AM
  #19
CstIrnFst's Avatar
A tip I'm sure you'll hear often about this troublesome gasket...take your time and do it right the first time. Better to spend an extra hour doing it thoroughly, rather than having to do it again a few months later when it starts leaking again. (yeah, I learned the hard way)
Old Jan 20, 2009 | 07:53 PM
  #20
jtarp's Avatar
ok i just finished with my intake the other day. Now i have a problem. Whenever i get close to or past half throttle the car studders and stumbles like crazy. Does this sound like i got coolant on my opti? I was careful and tried not to get any on it, but maybe i did. Does this sound like thats what happened?
Old Jan 20, 2009 | 08:50 PM
  #21
deerslayinrenek's Avatar
how would you have gotten coolant on the opti?......I just took my intake off on Sat and didn't spill a drop of coolant
Old Jan 21, 2009 | 08:19 AM
  #22
That Camaro Guy's Avatar
I would check and re check everything you disconnected, best place to start.
He probably didn't do a TB bypass.
Old Jan 21, 2009 | 09:08 AM
  #23
CstIrnFst's Avatar
I would double check any hoses you had to disconnect/reconnect. Very easy to miss one when doing that job.
Old Jan 21, 2009 | 02:44 PM
  #24
Mine doesnt have the TB bypass on it and there really wasnt anything come out......Also while i'm on that subject, is there any downsides to the TB bypass......it been from like -14 up to about 15 degrees around here and i wondered if that would have any effect.
Old Jan 21, 2009 | 07:09 PM
  #25
jtarp's Avatar
i was thinking i might have gotten coolant on the opti when i disconnected the line to the throttle body as it had coolant in it and some poured out. I will check all the lines etc as soon as i get a chance.
Old Jan 21, 2009 | 11:53 PM
  #26
Jon_Esslinger's Avatar
hows the vacuum?
Old Jan 22, 2009 | 05:03 PM
  #27
jtarp's Avatar
all vacuum lines seem to be fine as far as i can tell
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
