Intake manafold leak
Old Feb 7, 2009 | 11:02 AM
lt1le2's Avatar
How can u track down a Intake manafold leak?
Old Feb 7, 2009 | 11:40 AM
Oil leak, or air leak?
The common problem with typical LT1 intake manifold oil leak can be detected by wiping the back of the head/top of the block with a paper towel. If its leaking oil, you will find a lot of black gunk and oil on the paper towel.
If you are looking for air leaks at the gaskets, there are several things you can spray on the suspected areas, listening for a change in engine operation.
Old Feb 7, 2009 | 03:58 PM
lt1le2's Avatar
manafold
I am looking for a Air leak what can i use to find it
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
ModdedNerd
Jan 29, 2015 07:23 PM
artic94
Jan 17, 2015 11:19 AM
Dr. Weir
Aug 2, 2002 02:36 AM
