intake gasket problem
Old Jan 30, 2010 | 01:53 PM
z28_4life's Avatar
So my mating surfaces were sparkly clean and I was about to install the new intake gaskets on the lt1 when I noticed a problem. Three of the four plastic intake tabs had come off inside of the head. Two of them are slightly above but barely and one is recessed deep into the hole. I thought these things were supposed to stay on with the gasket because this has never happened to me, what a pita. Everything was running smoothly too. Any thoughts? I was thinking about gluing a small object that is similar in shape to each of them to try and pull them out. The only problem with that idea is that it would take a while for the glue to harden. help
Old Jan 30, 2010 | 04:35 PM
RamAir95TA's Avatar
Why can't you just pick them out with a small screwdriver? Heat them up a bit to soften them up and just pick them out.
Old Jan 30, 2010 | 06:45 PM
z28_4life's Avatar
That was my initial tool of choice. The problem is even a VERY small screwdriver is almost too big and it's not able to get underneath of it. I was able to remove them by using a small food skewer and piercing through them...haha. Hey, you have to be creative sometimes. On a side note, a VERY small hooked screw driver would probably work best for this situation. However, I didn't have a tool of this sort, hence me using the skewer.
Old Jan 31, 2010 | 01:14 AM
RamAir95TA's Avatar
When I meant "small screwdriver," I meant eyeglass screwdriver-sized.
Sometimes you just have to use your head.
Old Jan 31, 2010 | 09:14 AM
Your tool box should include a set of mechanic's "picks"..... like your dentist uses. They are invaluable in situations like this.
Old Jan 31, 2010 | 03:40 PM
z28_4life's Avatar
Exactly what I was referring to. I never knew they even existed for mechanical use, thanks for the notice. The 2nd to last one would have worked perfect for this situation.
Old Jan 31, 2010 | 03:55 PM
You can get even finer ones from medical equipment suppliers.... the cheap Pakistani rip-offs are more than adequate for working on your car....
http://www.indigo.com/images/product/21.jpg
http://www.indigo.com/tools/dental-picks-probes.html
InfernalVortex
Jan 17, 2015 09:35 AM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
