Intake and fastburn heads question
Old Feb 13, 2005 | 09:54 PM
350ws6's Avatar
I bought a set of GM fast burn aluminum heads for a Gen 1 SBC, and want to use a LT style intake. Will the LT-1 fit these heads, or is an LT-4 intake required?
Which intake gasket does a LT-1 intake use, an LT-4?
Thanks in advance.
Old Feb 14, 2005 | 12:02 PM
Re: Intake and fastburn heads question
You need an LT1 intake that has been converted to match the bolt locations and bolt angle of the Gen 1 heads, and has added coolant passages required for the Gen 1 heads. You can get the intake already modified. Try a "search".... I know the link has been posted here several times.
[edit] found it:
http://www.lt1intake.com/services.htm
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
thenewkid
Nov 27, 2014 09:41 AM
