Intake elbow...
So, when the guy swapped a 96 lt1 into my 94 car, he kept the intake elbow with the extra oval tube coming out of the bottom for the vented opti (i think). That's essentially running with an opening in the intake elbow... so i'm assuming that shouldn't be happening.
I'm experiencing some slight acceleration stumbling, could this be causing it by messing up air/gas ratios? I'm definitely going to order a new elbow without the vent hole for the opti... but just curious what problems this could be causing...
Thanks.
Thanks.
Re: Intake elbow...
Originally Posted by bugg1
Yep. You are getting air into the motor that the PCM doesn't know about.
Re: Intake elbow...
yep probably. When your cruising the computer makes small adjustments based on a lot of factors O2 sensors, TPS, etc. Under hard accelleration the computer looks more to TPS and MAF. Just my 2 pennies. Smarter people may disagree.
Re: Intake elbow...
Originally Posted by robvas
That tube is a resonator to reduce intake noise. You can order an aftermarket metal replacement, or a rubber one from the dealer/ebay/junkyard.
Some people plugit up with a lid from a deodarant stick
