instead of grease can i use wd40 on injectors?
Old Jan 8, 2006 | 05:41 PM
red96z's Avatar
when installing them into the intake ?
Old Jan 8, 2006 | 05:49 PM
1 Nasty Bird's Avatar
Re: instead of grease can i use wd40 on injectors?
I always just dipped my finger in a lil clean engine oil and put a tiny bit on each o-ring.
Old Jan 8, 2006 | 05:52 PM
red96z's Avatar
didnt even think of that .........
Old Jan 8, 2006 | 06:04 PM
96capricemgr's Avatar
wd40 has almost no actual useful uses in the garage, lubricant being about the least useful it can be.
Old Jan 8, 2006 | 07:54 PM
The Engineer's Avatar
Use a good brand silicone lubricant on the injector O-rings. Also, on the fuel line O-ring seals.
Old Jan 8, 2006 | 10:53 PM
Do NOT use any product containing silcone on the air or fuel system of your car. Silicone destroys the O2 sensors. Doesn't take much to screw them up.
Old Jan 8, 2006 | 11:35 PM
oneslowz28's Avatar
wd40 will fry out any rubber seal the same goes for liquid wrench, pb blaster ect. just go get a small tube of the injector grease or some kind of non sisicone white grease and you should be fine.
Old Jan 9, 2006 | 03:55 AM
Good ol motor oil has always worked for me for many years of abuse and extreme heat and cold, injectors still pop out fine in the end and stay sealed.
Old Jan 9, 2006 | 07:55 AM
Heatmaker's Avatar
Advanced Member
Here's what I do... simple and cost no money... yo uwont even have to go furthen than a foot.
Step 1. Remove oil cap from Valve cover
Step 2. Stick finger in valve cover hole
Step 3. Apply oil to sealant ring on injectors
Step 4. Re-install injectors
Step 5. Re-install oil cap
Old Jan 9, 2006 | 08:25 AM
kick Z tail out's Avatar
An easy little jewel that will guide you through life... Keep the can of WD40 at least 20 feet away from your car.
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
