installing roller rockers for the first time
Old Oct 13, 2010 | 09:28 PM
MyFastTA's Avatar
I was just making sure I was doing it right....It is a brand new engine I soaked the lifters in oil for days before install and they are the comp cams lifters....I am installing rockers per shbox.com using the 1 and 6 method....I am lifting on the rockers until they have no up and down play going maybe a 1/8 of a turn more and tightening the polylocks... The reason I am doubting myself is cause the lifters on most of them are extremely easy to compress and when running down the nuts I am able to do them by hand...I believe I have it adjusted right but I just want input....thanks guys!!
Bryan
Old Oct 14, 2010 | 06:59 AM
RamAir95TA's Avatar
Bryan
Once you are sure the lifter is on the base circle of the cam, tighten down the poly lock until all slack is taken up between the pushrod vertically. Some people argue that quite often the twisting method is inaccurate and you should just move the PR up and down until it has no more movement. Once you have found zero lash, add your preload minus 1/16th of a turn (so if your recommended preload is 1/2 turn, add 7/16 of a turn of preload. Tighten the set screw snug, then turn BOTH the poly lock AND set screw together the final 1/16th of a turn. Many people add their full preload to the poly lock then crank down the set screw only to have them loosen up.
I have never had a rocker back off with this method.
Old Oct 14, 2010 | 10:58 AM
Bryan
Any method on my site will work. The reason you can run the poly lock down by hand is that there is no interference like with the stock nut. You lock it with the set screw. 1/8 turn is not much for a stock lifter. You might want to go around 1/2 or so.
Old Oct 14, 2010 | 11:02 AM
MyFastTA's Avatar
thank you very much I will put a 1/2 preload on it and re do it today...I would like to get it right while it is on the stand instead of under the cowl
Thanks guys
Bryan
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
