installing roller rockers for the first time
I was just making sure I was doing it right....It is a brand new engine I soaked the lifters in oil for days before install and they are the comp cams lifters....I am installing rockers per shbox.com using the 1 and 6 method....I am lifting on the rockers until they have no up and down play going maybe a 1/8 of a turn more and tightening the polylocks... The reason I am doubting myself is cause the lifters on most of them are extremely easy to compress and when running down the nuts I am able to do them by hand...I believe I have it adjusted right but I just want input....thanks guys!!
Bryan |
Originally Posted by MyFastTA
(Post 6504285)
Bryan I have never had a rocker back off with this method. |
(Post 6504285)
Bryan |
thank you very much I will put a 1/2 preload on it and re do it today...I would like to get it right while it is on the stand instead of under the cowl
Thanks guys Bryan |
