Installing new radiator
Old May 10, 2005 | 07:57 PM
mattybz28's Avatar
Anything I need to look out for?
How much coolent is needed to refill the system?
Thanks for your help!
Old May 10, 2005 | 08:22 PM
OBE1 95Z28's Avatar
Re: Installing new radiator
The radiator has plastic tabs on the sides that nest with the A/C condensor; pay attention to how they nest. The radiator will only hold about 1.5 gallons of coolant/water mix; probably a good time to drain the block too (then you'll need about 3 gallons of mix). Use distilled water, not tap water and premix to your desired percentage (between 30% - 50% coolant).
Nov 18, 2023 07:21 PM
calaban
May 18, 2020 06:43 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jan 23, 2015 01:13 PM
