Installing engine, I need a little help here.
Old Jul 19, 2004 | 08:49 PM
ChevyTuffD.A.'s Avatar
I have a quick question. I went to install the water transfer tub onto the back of the heads. Well there is a little ring with a rubber seal on it that goes in between the bolt and the big metal junk that goes up against the head. Is there also supposed to be some kind of seal that goes on the other side of the chunk that goes against the head? I would appreciate any information asap, we're hoping to drop the engine in tommorrow. Also does anyone know the size of the bolt that holds the motor mounts to the engine, and also an opti-spark bolt size.
Old Jul 19, 2004 | 08:59 PM
AsianSensation's Avatar
Re: Installing engine, I need a little help here.
I can answer 2 of those questions.
There is 2 crush washer per banjo bolt. One under the bolt head and one on the cylinder head.
http://www.97ta.com/misc_pic/misc70.jpg
The opti bolt size is 1/4"-20 X 2-3/4".
Old Jul 19, 2004 | 09:27 PM
Motor mount bolts are 3/8-16 x ¾. The forward one on the RH side is a stud for the negative battery cable.
Old Jul 20, 2004 | 12:05 AM
Loadre's Avatar
Head--Seal--Tube--Seal--Bolt
Make sure you use antiseize cause those things are a pain to get out if they're stuck.
Old Jul 20, 2004 | 12:26 AM
disco192's Avatar
Those bolts arent normal bolts. They have coolant passages in them. Im not sure if you need one, but if you just use a standard bolt it wont flow coolant between the heads. There is a hole that goes from the inside of the bolts and comes out where the bolt meets the tube shroud part.
Old Jul 20, 2004 | 03:23 PM
Alright guys thanks alot. A perfect example of why this site is very useful to so many people. I dont know where i would have looked for this info if I couldnt get it on here. Once again thanks alot, Ill be sure to let ya guys know when the car is finally running again for the first time in 11 months.
DirtyDaveW
Dec 1, 2016 05:37 PM
97z28k&N
Jan 9, 2015 04:58 AM
hotrodyou1
Dec 20, 2014 10:05 PM
ro2207
Dec 4, 2014 06:18 PM
Bearmans
Dec 3, 2014 05:28 AM
