Installing double roller need help?
Old Aug 19, 2003 | 11:15 AM
T/A lt1's Avatar
Yeah I was thinking of some sort of freeze plug but I fiquered I would ask you guys what you used when you dropped the stock chain. I already had the electric w/p on there but the shaft was still sticking thru the timing cover and leaking oil So if somebody can give me somewhere to buy a plug for the timing cover I would appreciate it. BTW it's a Coyes double roller chain. Thanks Clint
Old Aug 19, 2003 | 12:13 PM
95_RipperZ's Avatar
All I did was put a silver dollar in there and used a lot of RTV. Smoothed it nice and no leaks.
Old Aug 19, 2003 | 12:23 PM
Ken95Z28's Avatar
Take a look at these
Plugged Hole Pic Front
Plugged Hole Pic Rear
Basically used two washers and a nut/bolt than used some RTV to make sure it did not leak.
Old Aug 19, 2003 | 12:24 PM
94formulabz's Avatar
http://ken.lowrance.com/projects/CSI...mp/default.htm
That guy used a bolt and washer on his, but i don't know if that will clear the double roller.
good luck
-brent
Old Aug 19, 2003 | 12:25 PM
Ken95Z28's Avatar
Yes it will clear, I'm using a double roller currently.
Double Roller
Old Aug 19, 2003 | 01:42 PM
sssalah's Avatar
I just had this hole pluged with an aluminium sheet and filled with aluminium weld, then it was ground flat. Looks good and no leaks.
Old Aug 19, 2003 | 02:32 PM
T/A lt1's Avatar
Thanks I will try one of the above methods What size bolt and washers are those Ken? Thanks
DirtyDaveW
Mar 15, 2015 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
97 RedSS
Jun 10, 2003 07:58 PM
