Installing double roller need help?
Yeah I was thinking of some sort of freeze plug but I fiquered I would ask you guys what you used when you dropped the stock chain. I already had the electric w/p on there but the shaft was still sticking thru the timing cover and leaking oil
So if somebody can give me somewhere to buy a plug for the timing cover I would appreciate it. BTW it's a Coyes double roller chain. Thanks Clint
Take a look at these
Plugged Hole Pic Front
Plugged Hole Pic Rear
Basically used two washers and a nut/bolt than used some RTV to make sure it did not leak.
http://ken.lowrance.com/projects/CSI...mp/default.htm
That guy used a bolt and washer on his, but i don't know if that will clear the double roller.
good luck
-brent
good luck
-brent
What size bolt and washers are those Ken? Thanks
