Installing 94-97 Corvette LT1 in 94Z28 ???
Old Jan 20, 2005 | 12:45 PM
  #16
scoobysnax83's Avatar
Re: Installing 94-97 Corvette LT1 in 94Z28 ???
Originally Posted by 96capricemgr
The stock 2 bolt will take easily twice stock HP, once beyond that even if you have a factory 4bolt motor you probably want too look at aftermarket caps and such meaning factory 4 bolts were more or less to make snooty Vette owners think they got something extra.
That's one way to look at it. Not necessarily the correct way though...
Old Jan 20, 2005 | 03:03 PM
  #17
ASTROJOE LT1's Avatar
On the Corvette LT1 Engine the Bracket I am looking for is the one the AC Compressor, PS Pump. and Alternator mounts to.It is on the drivers side while the Camaro bracket is on the passenger side.
Old Jan 21, 2005 | 12:54 AM
  #18
CaptPicardsZ28's Avatar
OK...I will check tomorrow when I go over to the shop.
Old Jan 21, 2005 | 09:09 AM
  #19
WS Sick's Avatar
Originally Posted by CaptPicardsZ28
Thanks for the info Scoob...I thought the 4 bolt was stronger. Just making sure. I am only familiar with the 400 blocks and the difference between the 2 and 4 bolt mains. Glad you liked the thread.
I about died when the guysaid it would buff out...lol
Then your beer lather produced a chuckle as well.
Old Jan 21, 2005 | 09:11 AM
  #20
WS Sick's Avatar
The straigh 4 bolts on LT1s are actually stronger than the splayed caps on LT1s , but I would add some stronger material caps.
Mindgame went the all vertical 4 bolt route on his motor for this reason.
Old Jan 21, 2005 | 10:26 AM
  #21
This motor comes complete. Wouldnt it already have stronger material caps?
Old Jan 21, 2005 | 11:31 AM
  #22
WS Sick's Avatar
Unless youre needing a rebuild on the motor the stock nodular Iron caps will be fine. If you ever want to build a beast out of it in the future at that time I would replace the nocular Iron caps with some higher strength steel ones and have it line honed.
Moshbmx1
Jan 20, 2015 03:27 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
thenewkid
Nov 27, 2014 09:41 AM
