Comp Cams XFI Cams
Old Jan 21, 2005 | 11:16 AM
belac350's Avatar
Comp Cams XFI Cams
How does this cam look? Look at the lift numbers. The intake is more than the exhaust. This is the cam they recommend over the CC306. I have been searching for info about this cam but I guess its still new.
PART NO. 07-467-8
01 INTAKE MASTER 3016
02 EXHAUST MASTER 3037
03 ENGINE LT1 280XFI HR-13
04 GRIND NUMBER LT1 280XFI HR-13
INTAKE EXHAUST
DUR @.050 230 236
.006 TAPPET LIFT 280 288
LOBE LIFT .357 .360
VALVE LIFT .576 .571 WITH 1.6 RATIO
LOBE SEPARATI 113.0
ADVANCE 4
09 VALVE TIMING OPEN CLOSE
@ .006 10 INT 31 69
11 EXH 81 27
109.0 INTAKE CENTERLINE
Old Jan 21, 2005 | 11:43 AM
WS Sick's Avatar
Re: Comp Cams XFI Cams
I can see nothing really wrong with it, If you have an excellent flowing exhaust and well ported heads on the exhaust side a dual pattern cam is not completely necessary. But there are probably better cams out there depending on your set-up.
It looks simular in timing to the XE 230/236
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
alex5366
Feb 17, 2015 08:12 PM
