installing 160 stat
Old Jun 5, 2003 | 01:29 AM
PaulN64's Avatar
Question installing 160 stat
ok, just got my Hypertech 160 stat tonight and going to install it tomorrow. Just wondering if there's anything special I should watch out for. Thanks
Old Jun 5, 2003 | 01:53 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
anything to watch out for???
umm ...nope?
just make sure you get all that air outta the lines before you seal it all up when your done...
Old Jun 5, 2003 | 05:09 AM
Hyperspeed97z28's Avatar
gonna need some rags so ur opti dont get wet, its only 2 bolts after you remove your intake elbow and maf, i think its 2 10mm bolts...
Old Jun 5, 2003 | 08:34 AM
Easy thermostat change out
Old Jun 5, 2003 | 10:51 AM
PaulN64's Avatar
thanks for all the help....
160 stat install 101...need lots of towels! Even the car sitting over night, that was lots of coolant. Also, put towels in the TB and MAF.
Took it for a test drive and seems to work fine. No leaks, knock on wood. Thanks again
Rich_z28
Sep 13, 2002 03:35 PM
jeff94z28
Sep 11, 2002 02:01 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
