installed ported 52mm TB, now has 2k idle?
Old Dec 15, 2006 | 02:25 PM
87lt1rx7's Avatar
I installed a ported throttle body and now it idles at around 2000rpm. i have not messed with the tps at all yet. I assumed it would be set right considering it has no adjustability, but I have yet to get a scanner on it. any ideas?? my car is a manual so it doesnt kill me tooo much, just it is mainly annoying
Old Dec 15, 2006 | 02:28 PM
bingo's Avatar
Have you checked the adjustment screw for the throttle blades?
Old Dec 15, 2006 | 02:59 PM
Z95m6's Avatar
Yeah, maybe it was ported but the idle adjusting screw wasn't turned back down.
Old Dec 15, 2006 | 06:41 PM
chrism400's Avatar
Did you reset the IAC?
Old Dec 15, 2006 | 06:43 PM
Adjust the throttle stop screw slowly, until the idle is within factory spec. (800rpm on the M6, 550rpm in gear with the A4). Then check the IAC counts to insure they are in the range of 20-40 counts. If not, tweek the throttle stop screw until it is. Finally, check the TPS voltage to insure it is between 0.20-0.90V (many people prefer 0.65V). You may need to slot the TPS sensor to get the voltage you want;.
Old Dec 20, 2006 | 08:28 PM
87lt1rx7's Avatar
just an update, I did not have a chance to adjust anything and a few days ago the engine settled down to idle at a decent 1000rpm. i didnt question it. lol since than the car seems to idle down around 1000rpm consistently and runs well. thanks everyone for the advice
Old Dec 21, 2006 | 05:48 AM
matt65's Avatar
Sounds good.
Old Dec 21, 2006 | 06:28 PM
z282slo's Avatar
DAMN! Wish my car would fix itself!
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
