Installed new IAC...still has a bad stumble...
Old Jun 24, 2006 | 04:17 PM
95BlackTA's Avatar
So I put in the brand new IAC, and read on shoeboxes page that you start the car giving it some gas, then turn it off after 5 seconds. I then turned it back on and it is still running the same, so I guess new IAC didn't fix the problem. My scanmaster still shows the IAC running all the way down to 03 at idle after its warm(shouldn't go below 20 I think).
Is there a chance the IAC isnt adjusted right? Or do they pretty much adjust on their own? I drove the car for like 5 min...
Old Jun 24, 2006 | 04:51 PM
Re: Installed new IAC...still has a bad stumble...
The IAC should adjust itself after some driving and idling. If the counts are going that low, it sounds like you have a vacuum leak of some kind.
Old Jun 24, 2006 | 06:49 PM
TobyZ28's Avatar
I'm having the exact same problem right now. It gets right down to 00-03 w/ the AC off. It's an A4, so i'm wondering if the ~20 counts at Idle applies only to M6's that idle at around 800. Maybe the A4's have a lower count because the comp will idle us as low as 550?
I spent a good while with propane around everywhere I could think of looking for a vac leak, w/ no luck
Old Jun 24, 2006 | 07:43 PM
Manual or auto should make no difference. Another possibility is that the throttle blades are cracked too far open (normally not an issue with a stock TB).
Old Jun 25, 2006 | 03:20 PM
TobyZ28's Avatar
Anyone know what to use to adjust the stock TB on the car? torx? hex?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Noenav
Dec 6, 2014 07:35 PM
