Installed Longtubes, Now I'm Slower
Old Jul 29, 2004 | 10:36 AM
clownhair's Avatar
Significantly slower. I could tell on the first test drive that something wasn't happy. The engine shakes pretty bad at idle and has a very apparent hesitation. Now I have to try and sort things out. I did install new plugs and wires while doing the headers but I rechecked all the connections and they seemed good and tight. I also blocked off my egr gas feed but the egr itself is still on there and was wondering if the egr could be a culprit in this. How do you start to test for this sort of thing?
Old Jul 29, 2004 | 10:39 AM
Loadre's Avatar
Re: Installed Longtubes, Now I'm Slower
You've probably got a plug wire burning.
Chris 96 WS6's Avatar
Did you make sure you got all the wires on correctly at the opti? If you have a couple crossed it could run like garbage.
Old Jul 29, 2004 | 10:41 AM
clownhair's Avatar
Would it really run at all? I had the car at the track last night and it was still able to muster 14.4's but it was just way down on power.
Old Jul 29, 2004 | 10:47 AM
What did you use for O2 harness extensions?
Old Jul 29, 2004 | 10:53 AM
LWillmann's Avatar
Have you logged it to see if you've got a knock retard problem?
Old Jul 29, 2004 | 10:56 AM
clownhair's Avatar
I used the 18 guage wire they provided and spliced into them and made them longer.
Old Jul 29, 2004 | 10:57 AM
clownhair's Avatar
I don't have a logger to check this with.
Old Jul 29, 2004 | 11:01 AM
LWillmann's Avatar
The way you did the o2 extensions might have something to do with it.
Have you verified that you don't have any exhaust leaks?
Old Jul 29, 2004 | 11:02 AM
TransAmGT's Avatar
That's your problem...you have to wire in resistors with the O2 wire...just go to summit or thunder and buy extensions....much easier!
Old Jul 29, 2004 | 11:21 AM
clownhair's Avatar
I crawled under and listened and kind of felt for any air and all seemed to be well but I have not done anything extensive.
Old Jul 29, 2004 | 11:36 AM
CamaroBoy96Z28's Avatar
It would run depending on how many wires were crossed. I crossed 2 wires after redoing my header bolts and it ran. Ran like complete garbage, but it ran.
I have O2 extensions and definitely recommend them.
Old Jul 29, 2004 | 03:27 PM
clownhair's Avatar
checked the wires and they are all in good order.
Is it worth a shot for me to order the o2 extensions then? I mean that for sure could be the problem correct?
Old Jul 29, 2004 | 03:35 PM
z28marine's Avatar
For sure check the plugs and wires... a wire might be loose on the plug, a wire burnt, wrong order from opti to plugs, etc.... i would really check one of these first
Old Jul 29, 2004 | 03:39 PM
disco192's Avatar
try unplugging your o2 sensors
