Installed Longtubes, Now I'm Slower
Old Jul 29, 2004 | 05:43 PM
  #16
clownhair's Avatar
Re: Installed Longtubes, Now I'm Slower
Originally Posted by disco192
try unplugging your o2 sensors
ok what do I look for while doing this? If the car runs the same then its a problem but if it changes it is not a problem?
Old Jul 29, 2004 | 09:01 PM
  #17
LWillmann's Avatar
If it changes, then it's a sensor issue, most likely your extensions causing the problem.
If there's no change, then it's likely it's something else.
Old Jul 29, 2004 | 09:59 PM
  #18
revtime's Avatar
I spliced my own O2 extensions and did not use any resistors and mine read fine on my scanner. I have a 94 though, so OBD2 needs resistors?
Old Jul 30, 2004 | 07:53 AM
  #19
TransAmGT's Avatar
If you unplug the O2 sensors the computer will stay in closed loop and should run off a map already stored in the computer! So it should run smooth if the O2 sensors are your problem. My buddy drove his car 2 hours with open headers and no 02 sensors...it ran fine, just a little rich and horrible gas mileage but it was smooth for the most part!
Old Jul 30, 2004 | 08:33 AM
  #20
LWillmann's Avatar
My o2 extensions don't have resistors and they are fine.
Nov 18, 2023 07:21 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
alphaauto
Parts Wanted
Jan 23, 2015 06:17 PM
