Installed hotcam kit and car dies at idle.
Old May 22, 2004 | 04:51 PM
WrecklessZ's Avatar
Is this normal. I'm about to send my Pcm to pcmforless
Old May 22, 2004 | 05:20 PM
whatsup's Avatar
Although you shouldn't need a tune to get it to idle .....I highly recomend pcmforless... Are you sure you didn't adjust the valves to tight, vacuum leak maybe, wires on correctly....check the obvious, then recheck....then when your done with that....recheck again!!!
Old May 22, 2004 | 08:09 PM
Dave Feerst's Avatar
i'll second valves or vacuum leak if it runs smooth once you rev it up. wires if it just plain runs crappy. the cam may have a rough idle without tuning, but it should idle.
Old May 22, 2004 | 08:31 PM
rocmemphis's Avatar
Without a tune the hotcam should just run choppy at idle. First thing you should do is readjust your valves.
Old May 22, 2004 | 08:41 PM
stereomandan's Avatar
Yup, check to make sure the RR's aren't too tight like stated.
You can always tighten them back up after the car is running, with the valve covers off, if you are worried about them being too loose.
Dan
Old May 22, 2004 | 08:48 PM
detroit1994z28's Avatar
Re:
I just got the lt4 hot cam installed in my 94 camaro z28. My car idle at 500 just under 1k on the rpm. I took sent my pcm to pcm for less and It idles great right at 1k. Perfect idle and streetablity. - mike
LeftoverChinese
Jan 14, 2024 03:03 PM
CamaroHeed
Mar 18, 2020 09:50 PM
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
