installed hot cam, slower ets!
Old Sep 5, 2003 | 01:19 AM
razeak1's Avatar
I haven't had programming yet, or a stall, but I still figured i would get at least something from the hot cam. My car ran consistent 9.3s before warmed up. Tonight, I had to leave my car set for a couple of hours to get a 9.3. It is averaging a 9.5 now. Any feedback is appreciated.
Old Sep 5, 2003 | 01:26 AM
94GrayV6's Avatar
What were the 60' times before and after? Trap speeds?
Old Sep 5, 2003 | 01:28 AM
razeak1's Avatar
60 foot times tonight were in the 2.0-2.2 range. I think it was about the same before.
Old Sep 5, 2003 | 01:48 AM
pennys58's Avatar
You need a tune. Get a tune and you'll be just fine.
Old Sep 5, 2003 | 02:06 AM
ROADRAGE's Avatar
And a converter. The cam bumped up your powerband, weak gears and stock stall= suck
Old Sep 5, 2003 | 06:04 AM
1982z28with18s's Avatar
Yeah, cam plus 2.73's and no stall = major suckage. Get a stall or some gears. Wait, do you even have headers? If not, I think that could be a MAJOR problem also.
Old Sep 5, 2003 | 12:07 PM
razeak1's Avatar
The 2.73s are the least of my concerns. It ran 9.3s all day long stock with those gears, where most of the 3.23 cars I know were running 9.4s. I'm getting the stall this weekend and the progamming very soon.
Old Sep 5, 2003 | 12:14 PM
94 CAMRO Z28's Avatar
I think headers would help you a ton! That thing is just begging to breath! Also, when I did my hotcam kit swap the car didn't feel much faster. My best at the track before it was a 13.78. After the hotcam with the mods in the sig. I was able to muster out a 13.55...was kinda disapointed. I then got a pcmforless.com tune and a 160 stat and went to the track. It was perfect day for racing as far as weather goes and it was a lucky run but I got a 13.16@107. After the tunning the car was a night and day difference. A ton better throttle response, better gas mileage, and a LOT more power! Tunning should be #1 on your list right now.
Aaron
Old Sep 5, 2003 | 12:17 PM
droptop1's Avatar
yeah dude but the cam changes your whole powerband up. gives you less lowend power and more midrange and top end. i lost a little of my lowend but gained hella topend power. that cam really isnt an 1/8 mile cam. get some gears and a stall and it will feel totaly different.
Old Sep 5, 2003 | 12:24 PM
93Z4ME's Avatar
With the Hotcam Kit you should install a LT4 Knock Module, otherwise those Self Aligning Rockers can produce a false knock and cause an ignition retard which will rob all of that expected power gains and then some.
Old Sep 5, 2003 | 12:28 PM
Black_Z's Avatar
Why did you go with the hotcam before headers/stall/gears ?
With stock 3.42's, Longtube headers, cut-out and ET streets I ran 13.0X at 107mph all night long... in July. Even hot-lapping 3 passes inside of 10 minutes. Stock cam, stock programming, stock throttle body, heck I didn't even have a cold air intake, just a K&N stock filter replacement. The LT-1 is not as bad as people think and 12's are very doable with bolt on only.
Old Sep 5, 2003 | 12:32 PM
bandit_1981's Avatar
Hey Black Z, I is see you are from bowling green. Are you going to the national f-body convention. I reserved my room last week for the event.
Old Sep 7, 2003 | 11:09 PM
razeak1's Avatar
I lost a lifter, so I just went ahead with the whole hot cam kit, otherwise, I would still be stock. Instead, I now have to do further modifications.
Also, I know people in town with 3.73s, and only gaines .1-.2 out of it. So the gear swap is one of the later things on my list right now. After tuning and stall, then gears.
Also, how restrictive are the stock manifolds? After the manifolds, the exhaust on my car is VERY unrestrictive.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
