installed cc306 now brakes suck
Old Sep 17, 2004 | 05:30 PM
93transam1234's Avatar
i am guessing because of vacum..anyway to fix them
Old Sep 17, 2004 | 05:34 PM
S8ER95Z's Avatar
Re: installed cc306 now brakes suck
Good question...I havnt tested mine yet.. EEK.
Brakes suck bad? or just a little worse?
Old Sep 17, 2004 | 05:52 PM
well for me they are pretty bad...i have to put both feet on the petal or pump them to stop quick. i dont have abs and cant even lock up the tires
Old Sep 17, 2004 | 06:05 PM
S8ER95Z's Avatar
Thats reassuring.. any vacum leaks that you know of???
Old Sep 17, 2004 | 06:28 PM
hoppy95dcmss's Avatar
If manifold vacuum is to low you can install a vacuum tank. It will solve the braking problems. Does it feel OK at high rpms but bad at low rpms? If so jut install a tank.
Old Sep 17, 2004 | 06:37 PM
30696bird's Avatar
I can't even tell the differance after my install. like the previous post said.......Is it only at low rpm's or high and low? Make sure the rubber grommets on the booster and intake are in good shape. I would bet it's a leak somewhere. JMO
Old Sep 17, 2004 | 08:13 PM
96ta(nick)'s Avatar
check for leaks, i have a cc306 with ported heads and i have great brakes
Old Sep 17, 2004 | 09:44 PM
does that vacume hose that comes out of where the fuel lines are do anything? also i dont have the air pump any more, but i am pretty sure that doesnt do anything
Old Sep 18, 2004 | 01:18 AM
S8ER95Z's Avatar
evap canister
Old Sep 18, 2004 | 02:23 AM
smoknta's Avatar
There is a vacuum line that runes from the intake manifold to the brake booster. Is it there and is it in good condition?
Old Sep 18, 2004 | 04:02 AM
30696bird's Avatar
A.I.R. pump has nothing to do with vacuum or brakes. It is there to help with emmisions. I no longer have mine either, like I said I have grreat brakes.
Old Sep 18, 2004 | 05:51 PM
i got the car back today, and the brakes are only bad when i am ideling, if the rpms are up they work as good as before.
off topic but it is my post
what RPM do those of u with the 306 idel at in gear and in park?
Old Sep 18, 2004 | 05:53 PM
30696bird's Avatar
I had Ion tune my for 900 in gear...... 925 in park.
Old Sep 18, 2004 | 07:20 PM
Spinner's Avatar
My brakes suck too. Similar cam to 306. Just low vacuum at idle. I pull barely 10 inches. Get a Jegs or Summit brand vacuum canister. They're inexpensive ($50 or so) and do wonders for braking ability.
Old Sep 18, 2004 | 07:21 PM
S8ER95Z's Avatar
I got my brake booster hooked up tonight. My brakes are awesome..those with sucky brakes need to check for vacuum leaks!!!!!
Magenta_Hearts
Mar 25, 2015 10:24 AM
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
Collector Car
Jan 5, 2015 10:58 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
