installed cam, but didnt check dowel pin. help!!
i just had the engine builder install the cam and degree it, but i just remembered that i didnt check the dowel pin length. i read in shoebox's schematics and it says that non-vented opti's(mines a 93) arent driven by the dowel pin. should i worry about it or should i just leave it like that? would hate to tell the guy to pull out the cam and then reinstall it. help me out guys what should i do?
Re: installed cam, but didnt check dowel pin. help!!
so i shouldnt even worry about it? would this affect anything once i get the opti back on? just wanna make sure before i bring everything home. thanks
danielbmx
Aug 27, 2002 11:11 PM
Your cam is driven by a geared hole in the timing set.
