Install Trans Go Shift kit or not install?
Old Jan 12, 2004 | 02:20 PM
Hotwire's Avatar
Question Install Trans Go Shift kit or not install?
I've got pcm4less programming in my computer, LT4 conversion, stock tranny, 3.73s w/ zexel torsen rear, stud girdle, and 245 50 16s. I'm getting ready to install a TCI Super Street Fighter 3500 stall converter, and was wondering if I should install the shift kit that's been sitting on the shelf or not. The tranny shifts pretty dang hard now, pushes the rear out going into second easy, sometimes will chirp both rear tires going into third. I know everything is going to pretty much grenade soon, engine tachs out to 6000-6200 on wot shifts, if I get any traction I know the stock driveshaft and rear are gone, so what'da say?
Should I leave it on the shelf, or put it in for harder shifts?
Old Jan 12, 2004 | 03:01 PM
Javier97Z28's Avatar
Moderator
My tranny shifted pretty firm stock also.. after the converter install the shifts turned to mush.
I installed the transgo well over a year ago and my stock tranny has taken me to 1.66 60' times and 12.0's... I would go for it.
Old Jan 12, 2004 | 05:57 PM
Hotwire's Avatar
Thanks, I appreciate the input, I'll be dusting the box off sometime this week.
Old Jan 12, 2004 | 07:52 PM
hozb817's Avatar
I have Nitto's on a stock 10 bolt with a transgo and it shifts really hard. So hard my trans is starting to go O well its time for a TH400
Jan 23, 2015 01:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
