insanely dumb question....
I am installing a roller pilot bearing when i do my clutch swap and i was wondering how much and what kind of grease i should use? I know this is retarded, but do i use hi temp wheel bearing grease, or regular stuff or nothing at all?
thanks
trav
thanks
trav
Re: insanely dumb question....
I used wheel bearing grease. I might suggest staying away from teh roller bearing ones and use a bushing. I've heard bad stories about rollers going bad and they tear up the input shaft on the tranny.
really!?! i was always told that the bearings are better..that is weird.
what exactly happens with the bearings? Thank you guys very much for the new info and saving me a potentially huge mistake...
trav
trav
I have had a bearing fail. i was lucky that the input shaft wasn't harmed. The main reason bearings fail is lack of grease. Since I the bearing and the clutch, I haven't has any trouble with either. I now have 80,000 mile on both. The key is to pack the grease into the needle bearings.
i see, do you think it would just be easier to skip the bs and stick with the bushing...i mean atleast this way there is no risk of it flying into pieces.
trav
trav
Aug 7, 2015 01:26 PM
