Injuneer shoebox help please code100
Old Jan 25, 2004 | 06:53 PM
Zeueses 97 RamAir's Avatar
Today I had got on the car a little to about 5000 then the ses light came on went to autozone they said maf malfunction... I pulled it off cleaned it . Now I reset the Ecm and no code tested the voltage 6.2 volts.. Now by looking at those little springs in it one looks darker brownish, is there anyway you can tell by looking at it.... Oh I cleaned it a week ago, but the guy said check the bellow it might be getting air on in the sides....any other suggestions... Thanks Angelo
Old Jan 25, 2004 | 08:15 PM
Hmm...you said you got the code, then cleaned the MAF, cleared code and it has not returned. It sounds fixed. Do you still have a problem? Just the discolored wire?
Old Jan 25, 2004 | 10:04 PM
no it has not
Yes I cleaned it today and it never has come back... but if it was bad it should not return wheather i get on it or not right... at idle. Shoebox those sensors on the maf one is like darker brownish.. is that bad, thats what I meant by the color disfigararion...
Old Jan 25, 2004 | 11:38 PM
Monitoring with a scan tool would be one way of "seeing" if it was operating correctly. If you have no codes and it is running well, then you probably have nothing to worry about. The discoloration could be a stain or who knows what.
Old Jan 25, 2004 | 11:54 PM
What does "tested the voltage 6.2 volts" mean? What voltage?
Old Jan 26, 2004 | 01:41 AM
ok listen up!
The 6.2 volts was the reading I had got from unplugging the maf connector like shoebox has om his website. And I used the book or manual that you buy from off the shelf at the stores.. it says the voltage range from the maf or to test the maf is buy unplugging the maf and leaving the key in the on position... and it should read 5 to 6 volts...
Old Jan 26, 2004 | 10:25 AM
You mean you got 6.2V on the yellow wire from PCM pin B19. That would prove the PCM, but wouldn't prove that the MAF sensor is producing the correct frequency signal, proportional to air flow. Did you also check for +12V on the pink wire at the MAF harness connector end?
Old Jan 27, 2004 | 07:36 PM
How To
Ok So when I hook It up to the scantool what should my maf be reading at wot or idle... Or should I tap it with voltmeter.. Thanks
Oh by the wat no ses light since then so should I worry... Angelo
Old Jan 27, 2004 | 07:42 PM
Re: How To
Take a look at Fred's page: http://members.aol.com/InjuneerZz/ScanMast.htm
Injuneer
Apr 25, 2022 06:22 PM
Novo
Jun 14, 2016 02:58 AM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
gelbza
Jul 12, 2015 08:10 AM
