which injectors for LE2 package?
Old May 24, 2006 | 10:36 AM
  #16
Re: which injectors for LE2 package?
Originally Posted by SStrokerAce
Fred, you could also use the rwhp x 0.08 rule.
Bret
Bret:
Every time I recommend a large injector, I get a raft of **** from a few individuals who feel that the way to size an injector is to run it on the dyno until it can't supply any more fuel, then start cranking the fuel pressure up. When that fails, I guess they begrudgingly go to a larger injectors. Their "proof" that they are correct and I am wrong for using my silly numbers rather than real dyno experience, is that they are making 450+ flywheel with stock 24's, and their engines make more power than my engine, so obviously I don't know what I am doing . I just let my engine run on the grossly oversized 78's, wishing I was smart enough to figure out how to make 500HP on stockers.
The "0.08" factor uses 0.50#/HP/HR and a max of 80% DC. I guess I'm trying to make it a bit less conservative, assuming an 0.48 BSFC and 85% DC.
Old May 24, 2006 | 02:01 PM
  #17
BlackScreaminMachine's Avatar
I bought their #37 Racetronix injectors, work fine, set the inj constant a little higher and zero'ed out the PE table, and I had a near perfect A/F under WOT and a awesome A/F from idle to 2700.
Its all in the tuning in particular the VE tables
Old May 24, 2006 | 02:55 PM
  #18
SStrokerAce's Avatar
Fred,
I just modified your 0.07 factor by adding in a 15% driveline loss. I hear you though on this
"Their "proof" that they are correct and I am wrong for using my silly numbers rather than real dyno experience, is that they are making 450+ flywheel with stock 24's, and their engines make more power than my engine, so obviously I don't know what I am doing "
BTDT
A 42# injector will not be a problem at all.
Bret
Nutty's96
Parts Wanted
May 12, 2015 09:37 PM
dfarr67
Apr 10, 2015 07:44 PM
Bignasty85
Mar 3, 2015 04:05 PM
LT14LIFE
Feb 9, 2015 09:35 PM
