Injectors gone bad?
Old Feb 4, 2004 | 07:03 PM
GpMike24's Avatar
Question Injectors gone bad?
Just got alot of stuff done, as shown in the sig. But i am sorta hesitating or missing in higher rpms...the thing is, i still have my stock injectors that i believe have 150k+ miles. do you think fuel regulator and some 30#s could fix it?
Old Feb 4, 2004 | 08:35 PM
Josh-'04 GTO's Avatar
9 times out of 10, a skip/hesitation is the result of an ignition issue. I see you did plugs and wires...how recent? Is it the original optispark?
The only true way to tell what condition your injectors are in is to pull them and have them checked on an ANSU machine. That way the spray pattern and volume can be verified as well as cleaned beyond anything you can pour into the gas tank.
Old Feb 5, 2004 | 06:22 AM
IDOXLR8's Avatar
I would also recommend taking a look at your ignition coil. Typically a miss up top is due to a bad coil.
Old Feb 5, 2004 | 08:37 AM
GpMike24's Avatar
new wires, plugs, and opti. just went in w/ the rebuiold and ncoils want much before that(msd)
HectorM52
Jul 30, 2017 11:46 AM
TitoPR221
May 26, 2015 12:20 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
dale3in98
Feb 14, 2015 12:18 PM
Fatdog2
Feb 13, 2015 08:19 PM
