injectors ask,,,
injectors ask,,,
i rebuil stock my 94 z 28 ,,im put everithing ,, new right,,ok but i not put new injector on it ,, im start the car, the car start good like 5 second and shut down ,, i have a gas problems right,,now somebody can tell me, if is anyway to clean the injectors ?,,,,,another think the car was seat for like 19 mons ,,the gas still good in the tank,,,?? i hear the fuel pump work good i fell it on the lines ,,,if my problem is the injector ,,where i can fine the best injector price,, thank you
Re: injectors ask,,,
19 month old gas will crud up the fuel system. The entire system needs to be cleaned out.
Put a scanner on it and ffind out what shut it down. You can't assume it "fuel".
Originally Posted by MyShibbyZ28
You can have injectors cleaned and flow matched. I do not know how much it costs. Otherwise the cheapest way to get different injectors is to buy them used.
autoxr166
Sep 25, 2015 04:21 PM
