Is .578 enough for my cam dowel pin?
Old Jan 21, 2006 | 11:30 PM
SiCk PuPpY's Avatar
I reviewed the other threads on this topic, but could not find the minimum length for the cam dowel pin. My Comp Cams stick measured at .578, from the cam face to the pin. Is this enough or do I need to R & R the pin off the factory stick?
Cheers,
JD
Old Jan 22, 2006 | 03:42 PM
Re: Is .578 enough for my cam dowel pin?
Mock it up with some clay so you can see how deep it fits in the opti drive.
Old Jan 22, 2006 | 04:27 PM
SiCk PuPpY's Avatar
Thanks for the response,
i'll mock it up tonight; what's my minimum acceptable depth into the opti?
Old Jan 22, 2006 | 06:31 PM
Z95m6's Avatar
In my opinion if you get the opti to set on there go a head and run it. If it goes into the opti even a hair it'll work as long as its good enough to engage the opti. I'm pretty sure you'll be fine with the amount you have sticking out.
Old Jan 22, 2006 | 06:39 PM
I would start to feel uncomfortable if it got down to a third of the way inserted.
rideordie
Nov 5, 2019 04:52 PM
sscott
Jan 17, 2015 04:30 PM
Red97LT1
Aug 15, 2002 08:33 AM
smacz28
Aug 6, 2002 01:51 PM
