injectors
injectors
been having trouble with m car starting the injectors are getting a signal from the computer the lasttime i check but they aren't spraying during start up but if i put 12 volt power to em i tested all of them they will spray that way but just not when i'm trying to start
read this
http://www.hotrodlane.cc/Instruction...tionswitch.htm
also the injectors are ground controlled, so make sure you have constant power at the injector in start and run
Have you scanned for codes? There are several codes that shut down the fuel system, and not all of them turn on the SES light.
Might want to add basic info about the car, like year. Not all years of the LT1 are the same.
yea i checked the fuses they are good and the only codes i got was the maf sensor has low frequency i don't know what else it could be i have a new fuel and everything i don't think the fuel rail is stoped up
With the key on, check the voltage on the pink wire in each injector harness connector. Should be 12V.
Did you try starting it with the MAF sensor disconnected?
I'll repeat one more time - ADD A SIGNATURE WITH BASIC INFO ABOUT YOUR CAR. Not all years are the same. Your comment about the MAF low frequency code would indicate you have a 96 or 97, but why make the people who are trying to help you guess??????
autoxr166
Sep 25, 2015 04:21 PM
