LT4 Idles 1800???
Old Dec 13, 2009 | 05:36 AM
NewbieWar's Avatar
LT4 Idles 1800???
Well, like the subject says, when I first start her(LT4) up, she usually idles at 1800 at least for a while, I'm trying to keep her under the radar as she's quite loud.
after she's warm she cools back down to about 1100 maybe? I always remembered my 94 lt1 to idle around 700 rpms...
She's got the EGR valve blocked, and its throwing an EGR code, I dont have the means right now to hook her up to anything to find out what other codes, thats just what I was told when I bought it.
I looked through the guys posts, and found out he also had a code concerning the TPS, but it doesn't seem as though he resolved that issue.
Old Dec 13, 2009 | 08:15 AM
You need to get it on a scanner to look at live data. There is just no other way to know what is going on.
Old Dec 13, 2009 | 08:17 AM
NewbieWar's Avatar
I've got a hypertech, that is insufficent correct?
Old Dec 13, 2009 | 08:18 AM
Unless it has scan capabilities, it won't work.
You should check for obvious vacuum leaks.
Old Dec 13, 2009 | 09:15 AM
Only the OBD-II versions (96/97) of the Hypertech had scan capabilities, requiring an optional scan "cartridge" to work.
Which EGR code is it setting? The one for low flow or the one for the vacuum solenoid?
Old Dec 13, 2009 | 09:18 AM
NewbieWar's Avatar
I think you might have answered my question from a different thread, I've got a 94/95 lt1 hypertech programmer(never used it, came with the car)
I'm going to assume that it still has the original OBD-I that came with the car, and not with the LT4 engine
k1996z28
Apr 13, 2015 06:54 PM
Roadie
Feb 16, 2015 10:34 AM
ModdedNerd
Jan 29, 2015 07:23 PM
ddr698
Jan 9, 2015 10:05 AM
