? on injectors
Old Dec 21, 2004 | 04:37 PM
jtcz28's Avatar
? on injectors
I have a bad injector and would like to replace it....how hard is this to do and what all do i need to do?? By the way the car is a 97 TA WS6. Any help would be great thanks!!!
-Justin
Old Dec 21, 2004 | 10:16 PM
Lt1t56's Avatar
Re: ? on injectors
Its not hard to do, remove fuel lines with disconnect tool. remove vacuum line from fuel pressure regulator. unplug all injectors. remove 4 bolts holding fuel rail to intake, then lift straight up on fuel rail removing rail and injectors as one unit.
Now try to drain all the fuel from fuel rail into something because there is quite a bit in there.
To replace an injector just slide the metal clip holding injector to the side, install new injector, slide clip onto new injector.
Lube the injector O rings so they slide easy into the manifold on reinstall.
Old Dec 21, 2004 | 10:52 PM
OBE1 95Z28's Avatar
Re: ? on injectors
Before disconnecting the fuel lines, relieve the fuel pressure by unscrewing your gas cap and depress the schrader valve on the back of the fuel rail with a rag to absorb any gas.
Old Dec 22, 2004 | 11:01 AM
Re: ? on injectors
You don't even need to disconnect the fuel lines. Just loosen the clamp that holds the 2 hard lines to the drivers rear corner of the intake manifold.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
