Injector sizing?
Re: Injector sizing?
RC Engineering has some good calculators as well as info. Check them out.
http://www.rceng.com/
HTH,
Steve.
HTH,
Steve.
Originally Posted by 94 guy
i want to be able to spray a max of 200hp wet kit.
What is your A/F and injector duty cycle?
If they are both good then there is no benifit form going to a bigger injector other then the fact you will have to retune. I have seen
injector debates on both sides and have come to the opinion that as long as te duty cycle is ok and the A/F is where you want it leave it alone.
You should be fine with the 36 pounders. Dont want to run too rich.. My .02
