Injector sizing?
Old Jan 22, 2005 | 10:24 AM
94 guy's Avatar
Injector sizing?
i have a 396LT1 that has run 10.60's @128. i run a 36lb. injector right now do you think i would benefit from a 42lb? thanks
Old Jan 22, 2005 | 01:38 PM
Re: Injector sizing?
All motor, or with a power adder? Estimated flywheel HP?
Old Jan 22, 2005 | 01:49 PM
RBE17's Avatar
RC Engineering has some good calculators as well as info. Check them out.
http://www.rceng.com/
HTH,
Steve.
Old Jan 22, 2005 | 02:00 PM
94 guy's Avatar
i want to be able to spray a max of 200hp wet kit.
Old Jan 22, 2005 | 02:06 PM
EddieP's Avatar
Keep in mind that a wet kit doesn't use the injectors for fueling, so you're set if your current injectors are getting the job done N/A.
Old Jan 22, 2005 | 02:12 PM
kmook's Avatar
Advanced Tech Moderator
This should be discussed in an engine tech forum. Transferring, thanks.
Old Jan 22, 2005 | 02:47 PM
ejfagala's Avatar
What is your A/F and injector duty cycle?
If they are both good then there is no benifit form going to a bigger injector other then the fact you will have to retune. I have seen
injector debates on both sides and have come to the opinion that as long as te duty cycle is ok and the A/F is where you want it leave it alone.
Old Jan 22, 2005 | 02:49 PM
6spdpewterZ's Avatar
You should be fine with the 36 pounders. Dont want to run too rich.. My .02
Old Jan 23, 2005 | 12:33 AM
Let me make sure I understand your question... you have a 396 that has run 10.6@128 on straight motor. That would indicate that you are making over 600HP. Not sure how you could do that on a 36# injector, unless you are driving them close to 100% duty cycle. In that case, the 42's would be of benefit, if only to get the DC down to a more reasonable level, and extend the life of the injectors.
You don't "run too rich" with larger injectors, if you enter ther correct flow rate and offsets in the PCM.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
