Injector size for 355CID @ 450hp+? And other question.
Old Dec 2, 2005 | 10:08 PM
1BadZ95's Avatar
Question Injector size for 355CID @ 450hp+? And other question.
What size injectors do I need and do I need to run a higher preasure fuel pump to handle 450-500hp 355CID? Also, I'm having a hard time finding a fuel injected intake that the runners will match up to my Dart Pro 1 cylinder heads. Anyone have any suggestions without having to spend a grand.
Old Dec 2, 2005 | 10:28 PM
UtOhCop's Avatar
Re: Injector size for 355CID @ 450hp+? And other question.
I'd go with 42lb injectors
Old Dec 2, 2005 | 11:41 PM
hvyss's Avatar
I run 30 lb SVO's with my setup. Only at 15 on the pulse width on the injectors at WOT. And I have right at 400 RWHP N/A.
HVY SS
Old Dec 2, 2005 | 11:46 PM
For 500 flywheel HP, you should be running at least a 36# injector. Unless you have a very efficient tune, you will be over 90% duty cycle on a 30# injector, even allowing the 5% extra capacity in the SVO's at 43.5psi fuel pressure.
If you're talking 500rwHP, you'll need the 42's.
Old Dec 2, 2005 | 11:51 PM
MyShibbyZ28's Avatar
Here is a good formula for finding out...
lbs/hr = (max HP) x (brake specific fuel consumption) / (no. of injectors)
I think that is right...
ShibbyZ
Old Dec 3, 2005 | 05:18 PM
slp223's Avatar
I would go 36 or 38.
Old Dec 4, 2005 | 12:07 PM
ShibbyZ
It's not quite right... it ignores duty cycle.
(flywheelHP x BSFC) / (# cylinders x duty cycle)
Example:
(500 HP x 0.46 #/HR/HP) / (8 cyl x .85 DC) = 230 / 6.8 = 33.82 #/HR
A BSFC of 0.46 #/HR/HP would represent a fairly efficient tune. Some sites recommend a BSFC of 0.50 for NA engines and 0.60 for blower and (dry) nitrous engines. 0.50 is a bit conservative.
Old Dec 4, 2005 | 01:31 PM
1BadZ95's Avatar
Ok thanks for all the help guys, sounds like i'll need 42lbs injectors then. What about the intake question?
Old Dec 4, 2005 | 02:21 PM
Example:
oops, forgot duty cycle has an effect too. Atleast it is cleared up now
Old Dec 4, 2005 | 02:56 PM
crAzy95z28's Avatar
should i upgrade my injectors?
i have a 355 huge cam and stock heads/intake and 150-175 shot but i do have abigger fuel pump!
Old Dec 4, 2005 | 06:07 PM
Is your nitrous system wet or dry? You don't need larger injectors for a wet nitrous system. You would size your injectors based on the engine's NA HP. Given the mods you list, you probably should have something larger than a 24# injector..... although I'm not sure a "214/224 comp cam" is "huge".
Old Dec 4, 2005 | 07:34 PM
crAzy95z28's Avatar
im osrry the cam thats in the new 355 is a 238/242 565/579 lift
Old Dec 4, 2005 | 10:23 PM
This is off topic, but what kind of gas milage do you get/plan to get? manual or auto?
What kind of milage did you get with the 210/224?
Old Dec 5, 2005 | 01:25 PM
crAzy95z28's Avatar
i was getting bout 245-265 miles per tank!
maybe a 10-12 drop
Old Dec 5, 2005 | 03:01 PM
10-12 mile drop from the whole tank? That is like a 1 mpg drop. Good to know what is going to roughly keep the same milage. I plan on doing a 224/224 .525/.525 ZZ409, if those are the right specs....hopefully I'll have some good milage still.
