Injector size for 355CID @ 450hp+? And other question.
What size injectors do I need and do I need to run a higher preasure fuel pump to handle 450-500hp 355CID? Also, I'm having a hard time finding a fuel injected intake that the runners will match up to my Dart Pro 1 cylinder heads. Anyone have any suggestions without having to spend a grand.
Re: Injector size for 355CID @ 450hp+? And other question.
I'd go with 42lb injectors
I run 30 lb SVO's with my setup. Only at 15 on the pulse width on the injectors at WOT. And I have right at 400 RWHP N/A.
HVY SS |
For 500 flywheel HP, you should be running at least a 36# injector. Unless you have a very efficient tune, you will be over 90% duty cycle on a 30# injector, even allowing the 5% extra capacity in the SVO's at 43.5psi fuel pressure.
If you're talking 500rwHP, you'll need the 42's. |
Here is a good formula for finding out...
lbs/hr = (max HP) x (brake specific fuel consumption) / (no. of injectors) I think that is right... ShibbyZ |
I would go 36 or 38.
lbs/hr = (max HP) x (brake specific fuel consumption) / (no. of injectors) I think that is right... ShibbyZ (flywheelHP x BSFC) / (# cylinders x duty cycle) Example: (500 HP x 0.46 #/HR/HP) / (8 cyl x .85 DC) = 230 / 6.8 = 33.82 #/HR A BSFC of 0.46 #/HR/HP would represent a fairly efficient tune. Some sites recommend a BSFC of 0.50 for NA engines and 0.60 for blower and (dry) nitrous engines. 0.50 is a bit conservative. |
Ok thanks for all the help guys, sounds like i'll need 42lbs injectors then. What about the intake question?
Originally Posted by Injuneer
It's not quite right... it ignores duty cycle.
should i upgrade my injectors?
i have a 355 huge cam and stock heads/intake and 150-175 shot but i do have abigger fuel pump! |
Is your nitrous system wet or dry? You don't need larger injectors for a wet nitrous system. You would size your injectors based on the engine's NA HP. Given the mods you list, you probably should have something larger than a 24# injector..... although I'm not sure a "214/224 comp cam" is "huge".
im osrry the cam thats in the new 355 is a 238/242 565/579 lift
What kind of milage did you get with the 210/224? |
i was getting bout 245-265 miles per tank!
maybe a 10-12 drop |
10-12 mile drop from the whole tank? That is like a 1 mpg drop. Good to know what is going to roughly keep the same milage. I plan on doing a 224/224 .525/.525 ZZ409, if those are the right specs....hopefully I'll have some good milage still.
